96 civic lx manual transmission noise when clutch pedal is not pressed in
96 civic. When the car is at idle, the transmission makes noise. Not grinding but i'm not sure how to explain it. When I press the clutch in, the noise stops completely.
The car has 80k miles. Can this be the throwout bearing?
Seagull Management
Re: 96 civic lx manual transmission noise when clutch pedal is not pressed in
One or more of the 5 bearings inside the transmission is bad, throwout bearing will make noise when the clutch pedal is depressed.
not the throw out bearing. It is one of the two bearing on the main shaft. Input shaft bearing or the bearing on the other side of the shaft. For your trans it is most likely the input shaft bearing.
bigboys96civic
22
01-16-2012 01:33 AM
akacoke
06-27-2011 10:48 AM
ether.real
10-07-2009 06:49 PM
Ek9Max
03-15-2005 07:19 PM
