jdm b16a into 00 civic ex
ok so im swaping a jdm b16a obd1 motor into a 00 civic ex and will my stock shift linkage work? for the ecu ill be running a p28 chipped. what wiring harness will work with my setup? thanks
pic for the fun of it
Technical Hero
Re: jdm b16a into 00 civic ex
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
use your harness. You'll have to adapt a few sensor connectors (intake air temperature sensor, distributor plug, injector connectors, alternator plug)
So if i use my ex harneSs the only plug im worryed about is the dizzy plug cuz obd1 has two plugs and my ex harness has only one and if i splice them there is a uneven number of wires. So how does that work?so do u think my stock shift linkage will work? Thanks for the quick replies
joesteppy
14
02-16-2010 02:49 AM
