Help !!!! OBD2a-OBD2b distributor plug problem after engine swap into 99 Civic DX
how you doing honda-tech community ....
i have a big problem ....
i am puttin an obd1 motor into my ek ( obd2 )
am not trying to splice no wires or such ....
so i put an obd2 altenator on and obd2 injectors and now the problem
is with the dizzy the plug on the obd2 harness and the plug on the
obd2 dizzy ... there diffrent ... the one on the harness is big the one
on the dizzy is type small ... so why is this if there both obd2 ??
could someone help me and tell me what do i need .. this project is taking
veryyy long and now in ny it's freezing temperatures .... PLEASE HELP = ]
Seagull Management
Re: Help !!!! distributer/electrical issue ...
'99 - '00 Civics (Except Si/HX) use a single small plug for the distributor. All '96 - '98 Civics (and '99 - '00 Si/HX) use a single large plug for the distributor.
i have a dx 1999 civic but i doubt that matter because i bought the harness idk what year but i know it has the big plug so i belive i have a 96-98 harness with a 99-00 dizzy ??
Seagull Management
Thats what it sounds like, or you have a '99 - '00 Si or HX harness. If its an Si harness you can use it, if its a HX harness or a '96 - '98 harness you need a '99 - '00 harness or you will not have a working tach and speedometer.
i just rather change the dizzy correct ?? the dizzy has a small plug so am guessing it's a 99-00 dizzy ....
i rather get a 96-98 dizzy and call it a day am i correct ??
Seagull Management
Using a distributor that matches the harness wont fix your lack of working gauges. Unless like I said it happens to be a '99 - '00 Si. Take a look at your ECU plugs, if you've got an extra plug you've got the wrong harness.
i have an extra plug but not from the engine harness i belive it's from the dash harness ... the engine harness has 3 plugs and all plug into the ecu ... am going to take a pic of the plugs tomorow so you could see it ... of the ecu and dizzy/engine harn plug
as long as the car starts i have no problem i just need it to start for now then i gues i will have to change the harness ....
sk8shorty012
07-19-2008 08:14 PM
SpoolinEK9
08-19-2005 12:12 PM
V-SPEC 1
11-17-2003 09:27 PM
