Help fuel pump not turning on (solved)
So i was driving back home and when i got halfway up the hill up my driveway it randomly died. Tried to start it up again and it couldn't start. Tried starting it several times and i noticed that the fuel pump not priming. So here are the things i have done to try and fix the problem
- Connect the fuel pump to battery and it runs perfectly
- Jumped the 5 and 7 relay connecter and fuel pump didnt turn on
- Changed out the fuel/main relay
- Checked all fuses from under the hood and the dash everything works
- Changed out the ECU
- Checked my grounds from the thermostat, tranny etc.
Anyone got anymore ideas on what could be the problem? Seems like i dont have power going through.
* EDiT *
- 95 Honda Civic Sedan
- Automatic
- D15b7
- All stock no mods
- Viper Alarm
* EDiT *
- Automatic
- D15b7
- All stock no mods
- Viper Alarm
Re: Help fuel pump not turning on
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
Was the key in ON(II) when you jumped terminal 5 to 7 in the main relay plug? If so, a fuse is likely blown. Test installed dash fuse 24 (92-95) or dash fuse 13 (96-00) with a test light as described at the Fuse link in my signature.
Might just be a bad fuel pump. Thats a sign of a bad fuel pump there. Most fuel pumps give out under strain, kinda like the hill u talked about. Also Might die in idle, But a fuel pump will warm u and give u signs. Was the car kinda jumpy? does the start on the car seem kinda slow and non responsive? does your car die under a long trip?. Just some ideas. But ive had a car with a bad fuel pump that was giving out. yours might have just died on u. Thats a 85 dollor fix. Takes your *** to autozone and buy that fuel pump, Its a hella easy installment.
Did you check dash fuse 24:
If fuse 24 is fine, check whether terminal 5 in the main relay plug gets voltage with the key in ON(II). It should.
Fuse 24 was out!!! i swear they all had power but i decided to pull out all fuses and the 24 fuse went out. Thanks you so much for your guys help i highly appreciated!!! Thanks again!!!
potatostix
10
06-17-2023 10:27 PM
slimsam1
11
12-28-2008 01:30 AM
juanchoenuncrx
08-29-2007 07:59 AM
2camsaam
18
04-13-2004 03:47 AM
