speedometer, Speed sensor help!??!
bought a 1995 civic si yesterday and the previous owner included an extra speed sensor, because the speedometer works sometimes and the other times it does not. rpm,gas,heat all work still but the odometer and trip dont work when the speedometer goes out. today i put in the new speed sensor and the speedometer/odometer/trip still doesnt work. Is it possible that he gave me a faulty VSS or is there something else i can check?
i have searched this but i didnt find that anyone resolved their problem, so i gave up lol
after doing some reading i found alot of people were resolving this problem by replacing the cluster (if the new speed sensor didnt fix the problem), also people were talking about testing wires.. i am fairly new to doing work on cars myself so i dont no how to test wires or where to even start. can someone explain how, or should i just get a new cluster, or just point me in the right direction. thanks
Re: speedometer, Speed sensor help!??!
If you end up stumped like I did after following all the troubleshooting steps in the manual. Give this a try https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-civic-speedometer-fix-2792878/ it fixed all my issues and saved me from buying a new speedometer.
If you end up stumped like I did after following all the troubleshooting steps in the manual. Give this a try https://honda-tech.com/forums/showthread.php?t=2792878 it fixed all my issues and saved me from buying a new speedometer.
i appreciate the responses everyone.
i am not sure yet im going to get it tested today, i bought the car on friday and ive been pretty busy during autozones hours. the guy said the code was for the vss i think. i will let you know in a couple of hours once i know
I have ek same problem.. My problem was there was a blue wire under the intake manifold that was cut up by rubbing on bracket. Check ur fuse cus my Vss fuse kept blowing up every time I put a new one in. If that's not it try one of ur buddy cluster.
im working on getting a manual but i spent all my $ on the car lol does anyone know what fuse i could check?
ohsnapzafingcu
11-24-2008 12:38 AM
