92 civic cx hatch wont start! doesnt want to crank
i have a eg hatch cx with a LS the car wont crank and the fuel pump wont charge i change the main relay i checked the fuses i dont know wat could it be? any ideas?? ( car just make a click sound)
Re: 92 civic cx hatch wont start! doesnt want to crank
Sit in your car turn the key twice listin toward the back seats if your hearing a humming noise your pump is cutting on soon as it does crank it. youll have to try a few times to maybe get it going but um like you said fuel pump aint charging..? replace it? just my thoughts.
No. Check your wiring to the fuel pump itself. Try giving the gas tank a wack with the hammer and see if that helps any. If it does somehow start it is your fuel pump. If that does not work try replacing the main relay (located under the driver side fuse box). Check for blown fuses also.
omfg... epic FAIL
if your going to ask for help be more descriptive and pour information into a thread.
on what grounds are you saying your fuel pump wont charge?
all you've said is when you try to start (makes click noise)
click click means the voltage to the starter is insufficient.
has nobody ever had a dead battery?
check your battery , use wire brush and sandpaper and clean the insides of the metal cylinder clamps and the battery terminals. I see this happen all the time.
If the battery, transmission ground, and starter connections are good, then check the rubber stopper that presses on the safety starter switch at the top of the clutch pedal.
So I no this this an old post BUT I'm having the same problem with my car..did a gsr swap and now when I try to turn the car over nothing happens..I can hear a little tick noise when I turn the key but the fuel pump won't turn on and the car don't crank over..replaced main relay, checked grounds, got a multi-meter and checked all fuses under the hood and they all seem to be getting power..I'm lost with this and if anyone can please help me I'd epriciate it!!
