starting issues have searched tons
Old 12-06-2010, 03:13 PM
Alexpbnj's Avatar
Default starting issues have searched tons
Hey all I've recently had a b18b1 swapped into my 98hx I've had problems starting since day one it will start jump to 2k and the just fall to 0 if I hit the throttle it bogs and dies faster if I partially hit it repeatedly it will revup but do the same and die. It does this nonstop until the engine warms up after its warm i can turn it off and start it perfectly fine with no issues at all,
I've replaced
Plugs / wires
Iacv from a good working motor
Throttle body with the map and tps from working motor
Fuel pressure regulator
One sensor I see that is not plugged in is the one bolted into the top of the intake manifold just can't fit out what it is.
Also I've been told I should try changing my iat intake air temp sensor or maybe a fuel pump relay?
Any other suggestions I hate having this problem everytime I start my car
when its not warm
Old 12-06-2010, 04:03 PM
Former User's Avatar
Default Re: starting issues have searched tons
CEL codes?
Have you checked the cap, rotor, and ignition timing?
Old 12-06-2010, 06:28 PM
Alexpbnj's Avatar
i think my cel bulb is burnt out because i know i have it on for some stupid reasons and i have no cel, i reset my ecu after cleaning my iacv so i will get them pulled tomorrow and cap and rotor would make it runb crappy when cold?
Old 12-06-2010, 06:35 PM
Replace the CEL bulb and pull the codes.
Start by considering all ignition components for any type of misfire problem.
netfreak
08-29-2018 04:57 PM
TimKennard
01-02-2011 10:04 AM
Alexpbnj
12-06-2010 02:52 PM
Zensa
11-03-2007 09:17 AM
hmtcrxsir
11-30-2006 01:35 AM
Quick Reply: starting issues have searched tons
