my b16 boggs at low rmps HELP PLEASE!!
hello im new on here but here we go so i have a 00 civic si with b16 semi built..but at low rpms it boggs out and it does in every gear..i run priemum gas.. <a href="http://s1123.photobucket.com/albums/l542/brandon_jaskolski420/?action=view&current=PICT0221.jpg" target="_blank"><img src="http://i1123.photobucket.com/albums/l542/brandon_jaskolski420/PICT0221.jpg" border="0" alt="Photobucket"></a>
Re: my b16 boggs at low rmps HELP PLEASE!!
Im having the same problem with my b16 in my eg hatch.. After doing some research I think it is a bad fuel filter.... here is a link you can look at... Im going to change mine this weekend and see if it helps.. Its only 12.99 at advanced auto... http://www.ehow.com/facts_5183619_ba...-symptoms.html
yea i checked my plugs and wires and distribtor cap...let me know if the fuel filter fixs your problem and what does it mean if the timmyin is off by a tooth or 2?
so i checked my plugs and wires and distributor cap and everything looked good ...i took the ngk ridum plugs to napa and he said the gap is kinda wide on them? but other wise they looked clean!...anyways did the fuel filter fix your problem ownedevo? because my car idels rough..boggs out..and isnt as powerfull and that seem to all lead to a fuel filter!..also how it has a p28 ecu in it ..could it bogg out becuase of the tune its on?..please help thanks and if you need me to be more specific just say so!
