93civic bogging out
93civic bogging out
wats up? im just now joining this forum after one of my friends told me it was the best. So now im here with my 93 eg civic gsr.
im having a issue with getting my car to stop falling on it face in second gear but fisrt imma give specs:
bought my 93 eg last year from a dude who did a stock ls swap(turbo) 5spd into the car.it was running fine but even then when i hit second it would fall on its face and then catch up. then i had low oil pressure and and swapped out my stock oil pump for a gsr oil pump.all was great but it would still fall on its face.timing belt popped soon after and bent all of my exhaust valves. so i swapped in my gsr head onto my ls block.i also removed the turbo.after i removed the turbo it went even more flat on it face when i went into second gear and its still does it now.i have replaced my sparks,wires,distributor,cap and rotor,cleaned all grounds, ive tried retarding(to 22degrees) and advancing my timing(to an obscene amount.i have 450cc injectors in the car and even tried to see if the problem will go away with my ls injectors. i am stumped and been working at this for many days and is need of some help. thanks.
civicb18ls
09-09-2004 07:40 PM
GroundZer0 336
06-29-2003 03:46 PM
HotWheelz
10-08-2002 03:21 PM
AGen2integra
07-02-2002 09:09 AM
