*** B16 LINE FROM FUEL FILTER TO FUEL RAIL *** NEED HELP
I started smelling gas this morning so i popped my hood while letting the car warm up and noticed a leak coming from this line.
Will any B-Series Line work??? i called the dealer but they dont have it in stock and takes 2 days to come in
Does anyone know what part# this is? its for a 2000 Honda Civic SI.
Seagull Management
Re: *** B16 LINE FROM FUEL FILTER TO FUEL RAIL *** NEED HELP
You can probably use any B16A or ITR feed line. Beware though i've seen honda use 2 different feed lines before depending on the vehicle the engine is going in. (sometimes the lower end vehicles have just a solid nut at the end of the fuel rail where the line connects, sometimes its a damper pulsation nut, feed line differs between the two)
Part number: 16722-P2T-003 HOSE, FUEL FEED
Seagull Management
That and sometimes the bend where the line connects to the rail wont be right if using a completely different line. Compare the end of the old B16A feed line with a D-series line, if the ends are the same then it shouldn't leak.
im running a stock B16A with OEM fuel rail. this setup is in a 2000 EK Hatchback which originally brought a D16Y7. When i order parts i say its for an SI since i have a B16 in a EK chassis.
anyways,......... i just got offered this braided line from B&R Fittings for $40 locally. what do u guys think? it came off a 92-95 eg hatch with a B-Series. the dude says itll bolt on??
so i picked up an LS fuel line and bolted it on. everything seems fine...
do i still need a B16 line or it doesnt matter
Eran
24
10-25-2008 12:48 AM
