how to pin a wire back into the map sensor plug? (solved)
the middle wire on the map sensor plug broke off flush with pin that holds it into the plug itself, how do i get the pin out so i can put the wire back in?
97 civic 4dr, b16 swap.
Re: how to pin a wire back into the map sensor plug?
i was able to pop it out, but i cant get the old wire out, do they have these connectors at advance auto parts?
nvermind I popped it out and went to radio shack and found a connector and drilled ou the inside of the plug a little so the newconnector could slide through, problem solved
K i l l a B e e.
05-30-2009 02:28 PM
Gant
05-18-2005 08:47 PM
