no start 92 civic 1.5l (detailed)
got this
1992 honda civic
1.5 liter, 16 valve SOHC
4 door
i have fuel pressure, i have spark (all four), i would like to test injectors if anyone could tell me how i have a noid tool set i got at advance.
new
ngk plugs
fuel filter
new distributer (that one of the cover bolts broke in to so ill be drilling that out but zip tie works till i get it going)
new cover for distributer
new rotor for distributer
new wires for plugs all premium from advance and napa.
i cleaned and sanded down the thermostat ground.
i attempted putting TDC, and installing the distributer at pistion 1, cam gear shows UP at the top, the long skiny triangle that i think marks TDC for crank pully is lined up with the white line next to the 3 other lines.
i might have made a mistake not sure during the install and i will remove and reinstall unless theirs any way i can test that pistion ones on compression stroke TDC and the distributers actually on the cam the right way. i tested for spark tho do have spark, turns over qucik just wont start. relay clicks once on 2. ill check the engine code thing tommorow ill look for a how to.
1992 honda civic
4 door
new
ngk plugs
fuel filter
Re: no start 92 civic 1.5l (detailed)
Post the CEL codes.
The next step may be to compression test the cylinders.
Is spark bright white at all 4 spark plugs?
Have you hooked up the noid tester to see whether the injectors are pulsing?
Is the distributor installed 180-degrees out of phase?
Are the plug wires connected in the right firing order on the distributor cap?
Egkid95
10
12-15-2014 09:33 AM
scotty.b16a1
12-31-2012 01:54 PM
TorquelessB16
51
06-20-2006 05:48 AM
