wheel bearing issues
Recently my wheel bearing went bad on my 2000 civic ex.
i have swapped out the front knuckles for integra ones that had new wheel bearings pressed prior to me purchasing them, i know this is true because it was a friend of mine who did the work. shortly after finishing the knuckle i had the same vibrations on accelerate however the humming noise was gone so i decided to ignore it as i have shitty *** gsp axles from advance auto.
two days ago the vibrations got so bad i finally pulled the knuckle and had a new wheel bearing pressed. unfortunately the awesome acceleration death wobble was still at large. :/ i had my friend "a mechanic" press the bearing. hes one of the smartest mechanics i know however i wont rule out it could have been pressed wrong and this is a giant coincidence.
so honda tech i ask you, what could make 2 wheel bearings be bad directly after installing them on my car, i ruled out knuckles because they were changed, and also the pressed hub because the two i used were different both times. i'm just wondering if anyone else has ran into this problem and what steps i can take to fix it. i don't mind re pressing the bearing but there has to be some explanation as to how this happened twice within a months period.
-thank you in advanced
Re: wheel bearing issues
when i grab the wheel there's play up and down left and right, its about 4 to 5 mm of play and its very audible.
i just replaced inner and outer tie rods and upper and lower ball joints. im almost positive its this bearing.
are you torquing the axle nut to the right spec ? have you replaced the nut ? if the end of the axle is damaged it can keep the shaft from seating in the hub and then you don't get the right clamping load on the bearing . also what kind of bearings are you using
i replaced the axle tonight with my "lifetime replacement" siiiiick. :/ still shaking on acceleration. that was the same thought my friend had about the hub not seating correctly.
i just pressed the bearing if you didn't read btw.
i ordered an oem bearing from majestic honda however they sent me the wrong bearing, in a pinch i ran to my favorite advance auto and got one of their bearings. the weird thing is when i drove after replacing the knuckle it was immediately wobbly again.
Which leads me to believe either A, the bearing was pressed wrong, or B my knuckle is damaged or where the bearing gets pressed is damaged.
try changing the other axle also worn inner c/v joints can cause a vibration on acceleration
is your car slammed ? did you torque the axle nut ?
im thinking my problem is the hub, or the piece that gets pressed into the actual bearing itself.
