D16y7 intermittent misfire
So I was going to work the other day and almost to work then my check engine light started flashing and started misfiring really bad. I pulled 2 codes with my obd2 scanner and it was p1399 and p0320 I think. I finally got to work and started it and drove it on my lunch without any trouble and even drove it a couple more days. Well, it did it again. Same symptoms. If I let it sit, no problems for a while. Just wondering what everyone thinks it could be. It hasn't had a tune up since I got it, just replaced the wires with a good used set of ngk's. It only seems to do it when it is fully warmed up. Could this be the ignitor in the dizzy? I'm off tomorrow so I will look at it then, just want some advice on what to look for specifically. Thanks.
Re: D16y7 intermittent misfire
Im fixing to go to work, so if it happens again, i'll pull them. Moneys kinda tight with christmas right around the corner, I just need this engine and trans to last till spring, so i'm not really looking to do more work than I have to, just need a few more months out of it.
