small bubble coming from radiator with the cap off
Old 11-29-2011, 08:14 PM
akacoke's Avatar
Default small bubble coming from radiator with the cap off
Hi, my civic d15b7 wasnt passing smog test for couple times, i thought the headgasket was leaking, so my friend owns the smog shop did the sniffer test on the radiator with cap off, there is 0 HC , i know that usually means the headgaket is fine, now the car passed smog check after valve adj, new O2 sensor and sea foam, everything is running perfect, idle smooth. i did a visual inspection of leaks, found no leak. i dont have to add any coolant what so ever. i never have any hard time starting the engine, every time i crank the engine i try to listen, the rhythm is smooth and even the car never over heats, i know the ECT sensor is working correctly.
its just some tiny lil bubbles and big ones are like 1/10th inch 2/10th inch ones comes out from radiator sometime, after thermostat opens it doesnt come very often its like every 30-40 sec 6 7or small bubbles would come out. is this normal? i only had the cap off for about 6-8 mins. so right now it could be not doing it at all.
im a mechanic student, im just trying to learn and get everybody's opinion
Old 11-29-2011, 09:32 PM
akacoke's Avatar
Default Re: small bubble coming from radiator with the cap off
i just did some more research, can anybody confirm if its a bad radiator cap?
Old 11-29-2011, 10:59 PM
MegasXLR's Avatar
Bubbles are just air in there... usually you wait until the fan comes on before you put the radiator cap back on.
Old 11-30-2011, 12:19 AM
akacoke's Avatar
thanks for the input, i know its air, im not asking how to bleed or put on the cap.
but how is it gotten into the systerm? i wanna find if the cap is the cause of air getting into the cooling systerm
Old 11-30-2011, 01:41 AM
lazlong's Avatar
Pressure test the cap and system. Google for coolant or radiator pressure test. Youtube has some decent videos.
Old 11-30-2011, 07:09 AM
motegicivic's Avatar
If you want to play it safe get a new cap, pretty cheap. As for it letting air in, hard to say I would doubt it.
Old 11-30-2011, 07:44 PM
akacoke's Avatar
imma test the cap at school, but im pretty sure its not sealing properly, cuz i caught some coolant sitting on top of the cap coming from under the sticker.
i asked the my teacher and other classmates who're working techs, they all confirmed that if the cap its not sealing air would be sucked in during engine cooling down
i just bought a new cap from my local honda dealer, its like 14 bucks. not bad tho. thanks for your guys help, i appreciate it.
Old 12-01-2011, 11:11 AM
Compare the old to the new, the old one might be missing the rubber gasket.
I bought a new cap and the rubber gasket had come loose within a year, I had the old one in the trunk and used that. Both Honda caps.
Old 12-01-2011, 04:19 PM
akacoke's Avatar
i checked nothing is missing or cracked on the old one. i guess the new parts quality is not really as good as old parts
Old 12-01-2011, 04:25 PM
Pisses me off, the damn gasket detached and was in the neck of the radiator, doesn't go on right, so I used the old one for now.
Old 12-01-2011, 09:25 PM
akacoke's Avatar
theres 1 year warranty on the cap
Old 12-02-2011, 06:49 AM
Over a year old unforuntately.
Old 12-02-2011, 11:35 AM
akacoke's Avatar
i would just bring that broken one to them, they might just give you a new one, or its only 13 bucks, at least thats what i paid, you dont want a 10 dollar part to messup your engine
vtec2017
03-18-2017 04:24 PM
SnoopyMan
03-07-2013 08:26 PM
nbcivic
10-28-2007 09:09 AM
accordexchange
02-05-2004 09:31 PM
intekragsr
02-24-2003 02:14 PM
Quick Reply: small bubble coming from radiator with the cap off
