Front suspension HELP!!!!
So we have been having some rain the past few days and i was going home from the store yesterday when i skidded off the road and hit the curb . I changed out the rim as it was bent, but something else is wrong, the rim and tire is now sitting further back than it should.... where would be a good place to start looking for something else that could possibly be bent? the car is a 99 ex coupe.
Re: Front suspension HELP!!!!
my friend car did the same thing when smacked into a curb. It was the lca brace. He has an EK but i believe it's still set up the same way on an eg. Either way, like Ron said you need to get it up in the air and find out for sure.
That could be a number of things. You have to get it up as soon as possible. If you drive on it for to long you may damage other suspension compenents. The picture doesn't do much justice but I'd imagine getting a close up look will definitely lead to the source of the problem. If you need help locating a new part hit me up.
Edit: Didn't hit refresh before I posted. Haha.
Try Majestic Honda. GL
I unbolted the sway bar. it looks like it went back into place where it should be (after I unbolted it it moved forward some). So would the lower control arm be the problem?
I can't really tell from the picture.
http://www.hondaautomotiveparts.com/...ER+ARM+%281%29
Do you have any local people to take a peak at it for you? It's hard to tell from the angle. If it does end up being the control arm I just bought the exact same one for my car. I haven't received it yet but it was about half price from OEM. I'm going to test it out to see how it works. I can try to get you the info if you go down that road. LMK if I can be of any other assistance. Sorry I can't give you a solid answer.
pictures of axle.
Picture of the bolt after I unbolted the sway bar. There is a very small gap in between the bolt and the sway bar just can't see it in The picture.
Trust me. Your lca is bent for sure. It's not noticeable by the naked eye unless it's compare side by side. Your axle should be fine. There's slight possibility that the sway bar may be bent also. But you won't know for use until you find a replace lca.
The lca is 2 piece. Replace both of them.
