New Honda owner with a couple of questions
Hello all...
I just purchased my first Honda: 2000 Civic LX MT and had a couple of questions.
Is it normal to feel and see the shifter move/deflect under acceleration or deceleration? To me that indicates worn out engine mounts and/or shifter bushings. But it may be normal with the Civic; I don't know.
Also, is the CEL an actual illuminating light or is it more like an open window with a background red "flag" that drops? I don't have an OBDII scanner to check for any thrown codes.
Where the h*** is the grounding wire from the alternator to the chassis? I looked from above and below and could not find it.
Any help with these silly questions would be appreciated. While I know VW's in-and-out (GTI VR6, R32, etc.) I am lost about the Honda product and need some direction. I am glad I found this site.
Seagull Management
Re: New Honda owner with a couple of questions
There isn't one, the bracket is the ground.
Originally Posted by 94EG8
Yes. The shifter is a solid bar linkage directly connected to the transmission it has to move with the engine and transmission.
It's an outline. It should light up for a few seconds for the bulb check when you start the car and then go out.
I guess I was referring to the "Maintenance required" indication under the speedo. I really do not know what that specifically alludes to.
Seagull Management
Maint req light is basically a mileage counter for oil changes.
You can install Hasport motor and transmission mounts and it will stop a LOT of the movement if thats what you are looking for. If you want to spend that kind of money because some say they are pretty expensive, but the are performance mounts. If you do want to do this keep I'm mind that you will get some vibration because of the type of material they are made from but then again thats why they are "performance" mounts....
ultrarevvin1
Honda Civic (2006 - 2015)
01-08-2014 09:09 AM
94IntegraRS
05-23-2013 10:40 AM
TWM Performance
12-23-2011 12:08 PM
