at what rpm @ 70mph ex or dx tranny?
i have a dx motor i dont know what transmission it is though
but at 70mph my rpm is @ 3k on 5th gear
is that a dx or ex tranny?
thanks
thanks
Re: at what rpm @ 70mph ex or dx tranny?
I have a cx and that seems to be close to what mine runs at. Possibility it might be a cx?
Edit: Check out this link, you can choose different trannys in the pull down list below either one of the graphs. You can compare ratios and such...
http://www.fatboyraceworks.com/gears/
Its possible its an ex/si. My ex runs about 70 at 3000rpm in 5th I think.
Will have to double check at lunch.
can u guys check 65-70mph in 5th gear @ what rpm you are at
thnx
so i dont have an ex tranny but its very close
okay so can anybody with a dx tranny compare their speeds @ 65-70mph in 5th gear @ what rpm
Well for what its worth, on my my way to work today, I took note of my RPM at 70, and it was 3000 rpms exactly. I have a stock '95 EX transmission.
My speedo could be off though.
check the link.
transmission calculator
you can put the EX in one and the DX in the other and compare. check the graph for RPM at MPH. don't neglect to get the right tire size in there.
EDIT: the calc shows 70mph with DX wheels and tires that the DX trans is at 3150 RPM and the EX is at 3299.
I've driven by enough of the "your speed is" signs that local PD sets up to know that my speedometer reads 4MPH higher than actual speed. original wheels and tire size. just FYI.
check the link.
yes i know that it is off by 4-5 mph because i got a gps
guess only thing to really know is to pop out the case and count the teeths lol
my bad. that was the main page. the trans calc was one of the tabs at the top. link fixed.
here's a how-to from Bense for identifying without cracking the case.
I understand that you were looking for info on the DX and EX trims, but just as a FYI, my HX turns about 2800 @ 70 in 5th on stock size tires and wheels.
b series transmission are in way higher rpms at hwy speeds
well looks like mines a dx transmission
thanks for the help
thanks for the help
1000kg88hb
10
06-21-2007 09:31 PM
mycvc8u2
04-19-2004 09:51 PM
