1994 Honda Del Sol Troubleshooting - Honda-Tech - Honda Forum Discussion
Old 12-06-2011, 09:45 AM
Default 1994 Honda Del Sol Troubleshooting
Basically, the car has problems communicating with the fuel pump and also occasionally turns off while on the road. When I turn the key to the on position, the fuel pump doesnt turn on, so car wont turn on. But when it does decide to turn on, you can hear the fuel pump, then the car turns on. It only has about 115,000 miles. Here is what we have done:
-Change the fuel pump to a brand new one.
-Tested with a new main relay (back to the old one)
-Cleaned the battery
-tested the wires to the fuel pump with OBD, reads fine
-ECU codes read numbers 3 and 7 but find that irrelevant to problems with the fuel pump.
-Cleaned sensors
-Tested old and with new distributor. Doesnt fix the problem.
Miscellaneous
-Starter was changed a couple months back, it failed so we had to change it
-Had to disable security system (wore out and wouldnt allow us to turn on the car)
-oil change was done 3 weeks ago; fuel injector was cleaned. A week later, the car failed; dont find it relevant either.
Ive had recommendations to check the igniter. How does that work? We will be testing it with a new ECU today.
bap3221 is offline
Old 12-07-2011, 09:45 AM
Default Re: 1994 Honda Del Sol Troubleshooting
I had the same problem with a 93 del sol.
Replacing the ECU cured it.
My old ECU had oxidation on the outside of the case. I guess moisture got to the circuit board.
delsolintegra is offline
Old 12-07-2011, 09:49 AM
JDM-Punk's Avatar
havent had this problem with either of my del sols but wouldnt be surprised to hear moisture getting into the ecu, as sols are known for leaking (sometimes under the dash area which would put water right next to the ecu)
JDM-Punk is offline
Old 12-08-2011, 04:23 PM
yea, tried the ECU also. Weve tried everything and it refuses to turn on.
bap3221 is offline
Old 12-08-2011, 06:44 PM
hannslebo's Avatar
Have you checked your clutch safety switch?? But I guess the pump would prime if that was the problem!
hannslebo is offline
Old 04-10-2013, 08:42 PM
super late response but the distributor was the culprit in this problem.
Hopefully it helps anyone with this problem
bap3221 is offline
Old 04-11-2013, 05:06 AM
Originally Posted by bap3221 View Post
...the distributor was the culprit in this problem.
^Conflicting information and...
...The fuel pump would still prime even if you unplugged the distributor.
Former User is offline
David93DelSol
15
11-07-2017 12:59 PM
keeganeli
42
05-17-2015 04:36 PM
munchlax
01-21-2011 11:05 AM
crxnatic
07-07-2008 08:06 AM
sugarloafpkwy
12-22-2004 10:36 PM
Quick Reply: 1994 Honda Del Sol Troubleshooting
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
