Mini Me Swap Compression Question
Ok, about this time last year, I swapped a Y8 head onto my Y7 block due to a long-going battle with a blown head gasket and warped Y7 cylinder head.
SO, a year later with no running problems at all and decent gas mileage (30+) on REGULAR 87 GAS, I come across this:
http://www.knology.net/~jediklc/D.htm
Curious as to my compression ration on my car, I input my numbers as so (the values to the right are automatically calculated)
Block: D16Y8-D16Y7
Head: D16Y8-D16Y7
Piston: P2E-000 (USDM D16Y7)
Piston to Deck Height-OEM D16Z6-D16Y7
Head Gasket Thickness: now this is where I might be a little off on my numbers...I got the Head Gasket from O'Reilley's (a Felpro gasket compatible with both the Y8 and A6 motor, so should I enter the value for the 2 layer Y8 gasket or do you think it's the Y8-A6 gasket?)
The type of gasket makes a difference because if it's the A6-Y8 gasket, my compression is ~9.6:1
If it's the Y8 2 layer gasket, then my compression is ~10.2:1 (and I should probably be using premium gas)
I'm not experiencing any knocking and never have, and even running 1 degree advanced timing with no issues. But the head was milled/smoothed ~.001 of an inch (nowhere near the casting marks on the head) so not sure if that tiny amount would matter that much....
Am I good with my setup or should I confirm that headgasket thickness first?
OR is that 10.2:1 WAY too high?
XP
Block: D16Y8-D16Y7
Head: D16Y8-D16Y7
XP
The Grumpiest
Re: Mini Me Swap Compression Question
I think after a year you should be good regardless of what numbers that thing is spitting out. Never heard anyone one this forum report any negatives doing one of these swaps regarding compression.
Heh, thanks
Ok, got some numbers straight:
Apparently, that "2 layer Y8 gasket" is "made" by removing the middle layer of the OEM three layer gasket (which I did not do)
The OEM three layer gasket sits at .037...
So, according to the calculator, my compression should be setting at ~9.96:1
(so with the milled head somewhere around 10:1 but now I'm just doing guesswork)
Soo...yeah, I guess I'm ok with what I'm running on Regular gas
That calculator just freaked me out a bit ^^;;
One year and about 8000 miles later and no issues!
*knocks on wood*
Thanks for the input, grumblemarc
*knocks on wood*
EFstyle
11-05-2008 05:48 PM
haroldthefly91crx
08-14-2006 08:26 PM
Wes90civic
01-19-2004 11:13 PM
