car won't move in any gear, clutch doesn't even grab
b18 poor mans type r with a b16 tranny
racing down a straight away and was at about 120 in 4th gear at 9000 rpms and meant to shift into 5th gear but dropped it back down into 3rd revved it and then put it back into neautral. got to a yield and stopped. put the car in first gear and it wouldn't move. the clutch doesn't even grab. if i let off the clutch completely in gear it just seems like it's in neautral and will just rev and roll backwards. it doesn't move in any gear, or reverse.
need input asap!!
need input asap!!
Re: car won't move in any gear, clutch doesn't even grab
over-reving it like that could have cost u more worries with the motor than the tranny now. only way to know is to split the trans and motor apart.
yeah by the sounds of it, its definitly your axle. check that before you go tearing the whole car apart.
The Grumpiest
This guy detonated his transmission doing the exact same thing.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/so-i-broke-my-tranny-downshifting-bad-when-not-done-properly-1269221/
If it's just your axle, you got off lucky.
if it was the transmission tho youd be hearing all sorts of noises coming from it when you were in gear
loudsubz
05-09-2004 03:12 PM
