D16y8-Whats The Best Intake Manifold Gasket For Performer X?
Hello HT
D16y8 engine, replaced my stock intake manifold with a performer x intake manifold. My problem is that I have a Vacuum leak between the performer x Intake manifold and the head. I have been using the felpro gasket from advanced auto parts and it does nothing. I have used the felpro gasket + gasket sealant and i still have a vacuum leak. So my question is what gasket should i use? Would a Hondata/golden eagle gasket work? Should I use the Oem Gasket?
Some one Help! Its been 3 weeks with no solution.
Re: D16y8-Whats The Best Intake Manifold Gasket For Performer X?
any gasket will work man,
hondata gaskets block heat transfer from the head to the intake manifold but it costs a bit extra
When you install these gaskets, make sure you mate the proper side to the manifold, like with headers the sides are different.
if its a 96-98 civic you have to plug the air injection ports located in each runner on the flange (mated against the head) rite near the injectors. use a rivet gun and plug them. i used jb for the top big hole or u can use a plug. i had to do this on my performer x manifold on my turboD
