help on d16y7 - idle problem, iacv and ELD codes, and speedo doesn't work
What's up guys I need all the help I can get I bought a 96 ek
That has a d16y7 in it but it has a idle problem and its throwing a iacv code
And the speedo isint working it has a p2e obd2 ecu but i think the engine harness is automatic what do I do or what can I do to fix it
Re: help on d16y7 in my ek
no the y7 use's the same 3 wire iacv so should be a problem unless the harness (or ecu) is for a y8 (y8 auto 3-wire,standard 2-wire iacv) and the speedo plug is also the same for automatic and manuel trans does the speedo jump or just not work period ?
p1298 eld high voltage(shouldn't cause idle issues) p1509 is iacv circuit failure. so it's possible your iacv is bad or there is a wiring problem cleaning it won't have any effect.
Re: help on d16y7 - idle problem, iacv and ELD codes, and speedo doesn't work
Alright I got it fugured out thanks for the help guys
As u can Probley c Im a trial user but Im gana stay and join. If u guys have any
Advice for me about being a member I would like to hear it .
what did you find wrong with it ? it could help somebody else with a similar problem .
crxfreak1117
09-08-2007 07:05 PM
