Cracked exhaust manifold
96 civic EX
I wanted to know with a cracked exhaust manifold..........
Can you lose power?
Can it make the exhaust louder?
Would it set off a check engine light?
can it make the car run rich or lean?
Can you lose power?
Re: Cracked exhaust manifold
If the crack allows outside air to mix with the exhaust gases, then your engine will run rich = possible bad gas mileage, fouled plugs, cat destruction, and CEL code.
Ek Forever y0!
Yes, it can contribute to extra noise. You could take it to a muffler shop and just have them weld a bead along the crack and that will be a cheap temporary fix. An aftermarket header for the EX would also be very easy to find and ~$200-$400.
Mine had cracked/split right through the crotch of the manifold, yes it was louder, but I never noticed any decrease in power, it never made my CEL come on, and I was quite happy with the "Dorman" OEM type replacement, think it ran about $110/$120 ( since I keep my delsol in stock configuration )
I had a slight decrease in power, granted its only a SOHC, but it did make the car louder. It also contributed to the failure of the O2 sensor. Spend the $100 and replace it. It was a real easy swap just had issue with some old rusted bolts.
No CEL's by the way.
Got a new header, it was original manifold was cracked.
The idle seems higher, I am wondering will the computer adjust, since I had the crack before now I do not, can that make the idle higher?
xbabysharkx
17
02-08-2011 08:58 PM
SimpleAznMan
Honda Civic (2001 - 2005)
01-19-2010 07:20 PM
