99 si with b16a cel code problems.
Old Nov 28, 2011 | 04:44 PM
oem-em1's Avatar
Default 99 si with b16a cel code problems.
ok i got a 99 si it has a b16a in it , and im getting codes for crank position sensor and knock. i know the b16a ..dosent have the crank sensor .. but i changed the knock to a new one and im still getting the code.my car is hesitating a little and feels sluggish. any help would be good. would i be better off getting a jumper and running a p28?
if i dnt need to i wont id like to fix the problem instead of just avoiding it but if i have to i dnt mind either
Old Nov 28, 2011 | 04:48 PM
Former User's Avatar
Default Re: 99 si with b16a cel code problems.
What is the CEL code?
Old Nov 28, 2011 | 04:51 PM
oem-em1's Avatar
it says in the post,......one of them is for the crank position sensor and the other is for a knock sensor but i got a brand new knock sensor and still geting the code and the results of a faulty knock .
Old Nov 28, 2011 | 04:52 PM
oem-em1's Avatar
codes 23, and 54
Old Nov 28, 2011 | 05:01 PM
23 = knock sensor
54 = CKF sensor (not CKP sensor)
Do you have a CKF sensor installed by the crank gear?
Have you checked the knock sensor wire with a multimeter (short or open)?
Old Nov 28, 2011 | 05:04 PM
oem-em1's Avatar
no its a b16a jap spec dont come with ckf sensor. and no i havent check the wire, it shouldnt be anything wrong with it its clean uncut factory si harness. but maybe.
Old Nov 28, 2011 | 05:06 PM
There may be a wire trick to eliminate the CKF code.
You need to check the KS wire with a multimeter to ensure that it's good. If so, the KS or ECU is bad.
Old Nov 28, 2011 | 05:07 PM
oem-em1's Avatar
what do u mean by short or open ?
Old Nov 28, 2011 | 05:08 PM
Short = Short to ground
open = broken wire
A multimeter is needed to do these tests.
Old Nov 28, 2011 | 05:22 PM
oem-em1's Avatar
ok well , i found the thread on by passing the ckf and i did it yesterday but im still getting the code for it. maybe i did it wrong but its not giving any other codes if i did. and ok i will check the wire tomorrow i have a meter here.the wire was super short so i did splice it and extend it maybe could be an issue? how do i check the wire with the meter if u can help ?
Old Nov 29, 2011 | 06:21 AM
oem-em1's Avatar
Ok, so I tested the wire/ plug with multimeter and its getting signal, I rewired the plug everything is good. I reset the ecu .. unplugged the battery / removed back up fuse .. and it cleared the code. Went for a ride let it warm up went into Vtec a few times pulled over code 23 knock sensor came popping back up I dnt know what else to do.
Old Nov 29, 2011 | 06:38 AM
oem-em1's Avatar
ttt
Old Nov 29, 2011 | 11:25 AM
oem-em1's Avatar
All issues resolved car runs like a champ thanks. Please close thread.
Please post solutions. Tech forums depend on give and take. You take tech advice from members, and you give back by telling us what the solution was.
brcivic411
17
Aug 26, 2011 01:15 PM
Vcastro
Mar 29, 2008 02:35 PM
oranginal
Jul 6, 2006 02:17 PM
birds_sol_94
Aug 19, 2004 04:23 PM
