EK front LCA interchangable??
Quickie questions:
I know the 99/00 Si/SiR front LCA is a lil diff from the regular EKs.
In what ways in particular?
Will the 99/00 SiR ft LCA fit on my 96 Si w/o modifications?
Also the front sway bar end links are diff on the 99/00 SiR opposed to the regular EKs. Correct?
Worthwhile swap to have the 26mm sway bar??
Re: EK front LCA interchangable?? (sohcnotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcnotec »</TD></TR><TR><TD CLASS="quote">Quickie questions:
The endlinks are different between the SI and all the other models. Also, to run the SI LCAs, you need the SI shock forks as well.
Hatchb96
03-30-2012 08:51 PM
