AC bracket on a B16 swapped 93 coupe? 99-00 Si Bracket?
Re: AC bracket on a B16 swapped 93 coupe? 99-00 Si Bracket? (civic_tuner)
Sure it will bolt on the motor but if your looking to keep a/c you need a a/c bracket from a CRV or a VTEC Del Sol.
Re: (CHASER)
38930-P7J-000 - 97 CRV Bracket
Like CHASER said it will only fit a b16a if you do not have power steering unless you shave 1/4" off of the top of the bracket.
The crv bracket works fine on all B18 swaps with or without power steering.
The crv bracket is also alot cheaper than the del sol bracket.
jadugartir
08-19-2006 12:30 PM
wizzards581
03-08-2004 09:27 PM
