Another LCA and Sway Bar ???
I am a little concerned about the fitting of a sway bar. This sway bar, whatever it may be, will be installed on a 95 EX coupe with 94 Integra LCAs. My question is which sway to order. Do I order a sway bar for the Integra or one for the 95 EX Coupe? I am almost certain the sizings for the LCAs are the same. My only concern is that the sway bars from all the different manufacturers have different part numbers for both cars. Someone please guide me in the right direction. Thanks.
Re: Another LCA and Sway Bar ??? (pancake56)
a sway bar off a teg will fit on a civic. the whole suspension of a teg will fit on a civic. so you can go with either one. but remember this if you go 22mm or bigger you will need to get a a sudframe brace to. go with the a-spec racing on it comes with the 22mm itr sway and all the hardware that you will need. you dont want to rip out your sub frame. but if you got with a smaller sway bar you should be fine. our you could jyst pick up a sway bar off a teg and run with that. i have a full gsr suspenation on my civic now and it rides great. hope this helps some.
