check engine light on a 99 ex
i was on the freeway today and i was in 4th at like 7k for to long i guess and it cut of the fuel for a second and then went back to normal but now my check engine light is on.
how do i turn it off?
and what should i do to make sure every thing is ok?
I like my how-to better
http://www.hstuners.com/forums...23007
Yes, fix it before you go about resetting anything.
Not necessarily replace...but fix.
Sometimes you just have something that needs adjusting...other times you replace ****.
Find out what it is before jumping the gun
it means that that is the problem that needs to be fixed...not necessarily broken parts...some cars give codes for running too lean/rich etc etc....just get it scanned, KEEP THE CODE, fix the problem, clear the code.......
Re: (SOHC4life 96)
7k @ 4th gear on the freeway? Where you racing? tsk tsk.
Anyway main reason 22 comes up is because your low on oil pressure so your VTEC will kill off. Also i believe you visit limp land, fun times.
Check your oil level and then reset the code, if it comes back and alls good then clean the solienod out. If still nothing then theres more walk throughs to go through but i doubt it would go that far.
explain that a little more please
check the oil i got that
i dont know how to reset the code.
after i reset it what am i looking for to come back
Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d »</TD></TR><TR><TD CLASS="quote">how do i clean the solienod</TD></TR></TABLE>
There are 3 or something bolts on the VTEC silenoid. It's on the back left of the valve cover. Unplug it and take those bolts out. Some oil will come out even if the engine is cold. Anways, get some brake cleaner and spray the **** out of it. Then make sure that ALLLLLLLLLLLLLLLLLLLL of the brake cleaner is out. The little screen should be clean now. Put it back on, and your done.
