I Need A Pin Out For 02 Civic Gauge Cluster
Does Anyone Have A Pinout For An 02 Civic Gauge Cluster. I'm Looking To Convert My 92 HB Gauge Cluster To An 02. So I'm Looking To Get All The Details About The Pinouts And Possibly Voltages.
Thanks
Kyle
Thanks
Kyle
Re: I Need A Pin Out For 02 Civic Gauge Cluster (Kyssrt-4)
maybe this will help its from a 03 civic:
GREEN Connector:
Blue: From ECM/PCM, Tach input signal
White/Red: Constant 12 v +
Yellow: Switched 12V+
Blue/White: From ECM/PCM And VSS input signal
Yellow/Black: From fuel level sending unit
White/Green: From multiplex control unit
Black: Ground
Pink: (Canada Vehicles only) Washer fluid level switch
White/Blue: (Canada Vehicles only) DRL Control unit
Black/Yellow: Security control unit
Blue/Yellow: Cruise control unit
Pink/Blue: OPDS unit (Side airbags)
BLUE Connector:
Black: Ground
green/orange: From ECM/PCM
Blue/Red: From ABS Control unit
Pink: From SRS unit
Red/Black: Supplies 12V+ for dash backlights
Red: Supplies switched ground for dash lights
Green/Red: Left turn signal indicator
Green/Yellow: Right turn signal indicator
Red/Blue: Combination light switch
Blue/Orange: Immobilizer control unit
Red/Yellow: From no 15 fuse under hood
White/Red: From no 9 fuse under hood
Yellow/Red: From oil pres switch
GREEN Connector:
Black: Ground
BLUE Connector:
Black: Ground
Pink: From SRS unit
fventura03
Honda Civic (2001 - 2005)
10
07-31-2007 06:40 PM
