Helllllp im having issues with reatteching wires on the big driver side motor plug
Hey i baught my car as a theft recovery and the motor was stolen and the ***** cut the plugs off out of the firewall ..i got another plug and soldered most of the wires as as they were the same colours but now i have a problem ..i have some duplicat colours ...
heres what i got
on the cars harness side i have
2 yellow/green
2 black/yellow
2 blue
on the plug im attaching i have
2 yellow/green
2 black/yellow
1 blue
are both yellow/green wires the same values so are they interchangeable
same question as above with the black/yellow wires
and my cars harness has 1 more blue are bothe blue wires the same in which case i hook 1 up to my plug
heres what i got
2 yellow/green
2 black/yellow
2 blue
2 yellow/green
2 black/yellow
1 blue
Re: Helllllp im having issues with reatteching wires on the big driver side motor plug (Dirtyman)
on the wires that have the same color are they like green with a yellow stripe or yellow with a green stripe, cause they might look the same but in reality they ore completely different, and just to clarify, thats a huge cluster **** you go there
Re: Helllllp im having issues with reatteching wires on the big driver side motor plug (Soccerking30
thanks anybody else ...and was it right to match colours on the ones the where the same and only ones theye please help
and yes this is a cluster **** but wiring doesnt scare me ...wiring with out a manual scares me
I thought all the yellow and blacks on the drivers side were all 12V Power sources for all the sensors?
can anybody confirm this ... or help with the others
The wires that are the same colors should have a small circle on them. The small circle will be a different color. The wires will all have different color cicles for the ones that are the same. This shows that they are for a different part of the same circuit. Hope this helps. I had the same problem under my dash tracing an electrical problem luckily my good friends dad is an electrician .
Edit: The marks are usually silver and brown or only one will have the silver. And if this doesn't help i think it would just be easier to get a new harness from the salvage yard.
Dirtyman
04-10-2005 07:45 AM
88rexdxa6ed
14
05-06-2003 01:56 PM
