clutch?
clutch?
I just finished putting a cluthc in my civic and i started brining it down the road. i stoped at a stop sign and as a took off i heard a poping noise and my car had no gears it sayed running but i would cycle thourhg the gears without them engageing at all. does can anyone help me?
Re: clutch? (jjaskula1)
Sounds like your throw out bearing is stuck out, so the clutch is not in. Did you replace it? Also does the clutch pedal have pressure. Try bleeding it. Did you lube the input shaft lightly so it doesn't grab. Also did you mess with the shift fork? Maybe the popping sound was it coming off. Prolly going to have to take it off, but check the shift fork and bleed the clutch.
oXeNo
07-30-2011 09:12 AM
