changing shocks
changing shocks
i am changing my strut/shocks this weekends and wondering if there are any how to's for honda civic's. i found one that was done on a ITR in search, does that How to apply to civic's as well? https://honda-tech.com/zerothread?id=1106020
Re: (Relic1)
http://www.c-speedracing.com/h...r.php
Not shocks.. but pretty much the same thing, you just have to put the shock and the spring together.
Imperious: Mod of Valor
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1427142</TD></TR></TABLE>
Best thread ever!
Best thread ever!
Re: (dogbiscuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogbiscuit »</TD></TR><TR><TD CLASS="quote">are the torque specs the same?</TD></TR></TABLE>
To be honest, I didn't have a torque wrench when I did mine.. So I can't tell you.
Re: (dogbiscuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogbiscuit »</TD></TR><TR><TD CLASS="quote">should i go ahead and get PB blaster for this install, considering these old shocks are stock.</TD></TR></TABLE>
I didn't need one. I just used normal ratchets and it worked out fine for me.
Re: (dogbiscuit)
Yes, it will make the job much easier. I would recommend spraying some on the bolts the night before to let it sit and then spray some more before you start. It's not worth stripping the head off the bolt to your rear lower control arm just because you didn't want to spend a couple bucks on some PB blaster.
Unceasing Measure
Re: (bebfsu1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebfsu1 »</TD></TR><TR><TD CLASS="quote">Yes, it will make the job much easier. I would recommend spraying some on the bolts the night before to let it sit and then spray some more before you start. It's not worth stripping the head off the bolt to your rear lower control arm just because you didn't want to spend a couple bucks on some PB blaster.</TD></TR></TABLE>
I've definately mangled the bolts (broken them, snapped in half, sheared inside the subframe, etc.) because of mileage and a lack of proper preparation. PB blast it and have air on hand
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
I've definately mangled the bolts (broken them, snapped in half, sheared inside the subframe, etc.) because of mileage and a lack of proper preparation. PB blast it and have air on hand </TD></TR></TABLE>
Yeah you gotta be careful, I broke a bolt on my rear Driver side. Tapped it too hard. spray something on it to make it easier and less likely to break
i am going off topic on this but is this the Helm's manual i should purchase for a 1993 EJ1? http://www.helminc.com/helm/pr...G7LM4
