need help with my rpm gauge
hi im having a problem with my cluster. my rpm gauge don't work. it was working fine the other day. must be something i did. what problems might it be or what should i check to see will it fix it. i have a 95 hatchback si
well its not a fuse than, ummmm check your connector if you have a friend with a 92-95 civic swap cluster and see if the rpm gauge works in there car it could be your cluster
1 Post
Re: (o5mar1)
go to the pin on your cluster and test it for AC while the engine is running, the 12v ignition power for the tach gauge, and the ground for the gauge. a tach is a simple 3 input gauge. if everything is straight, then your gauge died.
