2000 Civic Timing Belt Change
My girlfriend's Civic is up for a timing belt/water pump change. Besides the actual belt and water pump, does anyone know what other parts(trivial or important) are needed for the job? A friend of mine through a new cam seal in there since his was leaking, but I think that may have been it. Any comments would be appreciated. Thanks!
Re: 2000 Civic Timing Belt Change (LicenzedToThrill)
Sometimes the Tensioner, Spring, Pulley, or Assembly as a whole needs adjusting/replacement. If the mileage is low, and the belts look near perfect, sometimes it's just a matter of retightening the Tensioner.
Check the Timing Belt Cover for any crack, then smoke it if you find it. It will make working on your car that much more interesting. Then try to remember to replace it and put it back on your car if you do...
On my hands and knees searchin for a piece of rock,
JasonGhostz
JasonGhostz
MugenHonda
11-16-2002 08:47 AM
