HELP NO SPEEDO....
HELP NO SPEEDO....
People my speedometer does not work, weird because it will come on after the car is running for a while. Once the car is off and cool and you start it again the speedo will not come on. I replaced the VSS and there is still no response. Would it matter where the VSS came from? what could be wrong besides the VSS. no codes..
yeAH im almost positive it was working. The speedometer works after the run is running for wild it comes on. But when you first start the car it would not come on at all. If the cluster was bad the RPM's would be out too and everything else?
The speedometer works after the car is running for a while. If you were to start it and drive it it would not come on until after. If the cluster was bad would everything else still come on??
Imperious: Mod of Valor
Re: (b17boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17boost »</TD></TR><TR><TD CLASS="quote">yeAH im almost positive it was working. The speedometer works after the run is running for wild it comes on. But when you first start the car it would not come on at all. If the cluster was bad the RPM's would be out too and everything else?</TD></TR></TABLE>
Not nessacarily. Try swapping in a new cluster and see what happens.
Re: HELP NO SPEEDO.... (b17boost)
is it just me, or does this seem to be a common problem? mine works very erratically, i know its my speedo, cuz I'm getting a vss signal. i should fix it, but i know how fast I'm going in 5th by watching the revs, and that makes me lazy
H-T Poker champion
Re: HELP NO SPEEDO.... (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 »</TD></TR><TR><TD CLASS="quote">is it just me, or does this seem to be a common problem? mine works very erratically, i know its my speedo, cuz I'm getting a vss signal. i should fix it, but i know how fast I'm going in 5th by watching the revs, and that makes me lazy </TD></TR></TABLE>
It is a problem.. With ALL "EG'S". What happens is: Overtime, the soddering inside the speedo comes loose. It's a problem that is extremely common, and it can be fixed by opening up the cluster and re-soddering the connections.
My car had this problem for a long time before I finally got around to installing my GSR cluster. Now that I have installed my GSR cluster, the speedo works 100% of the time. It is just poor design / craftmanship on the "EG" clusters.
So.. Either get a new guage cluster, re-sodder your current speedo, or dont have a working speedo!
Thanx ppl. I changed the VSS and it comes on more often than before...or maybe is just me. im getting an Sir cluster so we'll see how it goes with that one.
Re: (b17boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">
So.. Either get a new guage cluster, re-sodder your current speedo, or dont have a working speedo! </TD></TR></TABLE> Happened in my 95 DX, tested the VSS and it was putting out a very strong signal. Replace the cluster with a used one, changed the odometer to the correct mileage, and never had a problem.
When its not working, while your driving give the cluster a good whack with your fist, if the needle jumps VERY good chance thats your problem.
jumpin4abeat
19
04-15-2017 01:02 AM
virdizzeripsta
01-01-2014 11:58 AM
hondaboy4life
10-09-2006 09:35 AM
