WTF is this and where does it go?
Re: WTF is this and where does it go? (E.Honda)
Main relay for the fuel pump????
Inside under the steering wheel
This is a guess... i have no idea honestly
Re: WTF is this and where does it go? (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">Main relay for the fuel pump????
This is a guess... i have no idea honestly</TD></TR></TABLE>
I don't think thats it.........I hit the key tonite testing something else and had the injector rail loose and fuel sprayed........So the fuel pump must be working.
Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">where did you take it out from?</TD></TR></TABLE>
Well if I knew that.....I could put it back...lol
No clue........I don't see a plug that looks anything like it anywhere......Seems like I recall it being up underneath the drivers side somewhere.....
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">it's a power lock relay</TD></TR></TABLE>
Where does it mount?......Inside the door?
Modified by E.Honda at 9:41 PM 11/13/2005
Re: (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">it does kinda look like a power lock relay, which is inside the door,
my power lock/window relay is a grey box tho, 93 lx</TD></TR></TABLE>
Can anyone confirm this?
Thank you
E.Honda
Thank you
E.Honda
Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Is your car back together? What doesn't work?</TD></TR></TABLE>
Everything seems to work except the wipers.
Althought I don't have the doors back on it yet. The power windows will be an issue. I shaved the switches from the panel and moved them to on switch in between the seats in a custom built console. The wipers work ONLY when I pull back on the lever (as to spray the windshield).
Thanks.
E.Honda
Thanks.
E.Honda
Re: (E.Honda)
Also I don't use the facorty door locks. I shaved the handles and connected the power door lock actuator to the door relaease and connected that to my alarm.
The RHD clip I got was from a hatch. It has the switch on the column for a rear wiper. I think I will use the rear wiper switch for a starter kill. Stealth
Not too bright to advertise that on the net.
Re: (nitrared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrared »</TD></TR><TR><TD CLASS="quote">Free Bump
-Red</TD></TR></TABLE>
Thank u
Thank u
Re: (E.Honda)
im takin my door panel off tomorrow to try and fix something with my regulator, ill take a look inside there to see if i see something that looks similar or the same.
Hey, yeah that I think does come from under the driver side dash, what exactly its supposed to be connected to I'm not entirely sure, I think I've seen sumthin similar in mine but it goes back into a massive wire harness, but i would suggest that's where you start lookin to reconnect it
haha, to me it looks like the relay for the jdm power folding mirrors. its doesn't go in the door. the relay that controls the locks is bigger than that and also has a bigger plug. it goes under the dash.
Re: WTF is this and where does it go? (shyboi4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboi4u »</TD></TR><TR><TD CLASS="quote">haha, to me it looks like the relay for the jdm power folding mirrors. its doesn't go in the door. the relay that controls the locks is bigger than that and also has a bigger plug. it goes under the dash. </TD></TR></TABLE>
This is very possible.........I just did RHD conversion.
I had a massive pile of parts in the shop.
Just want to make sure I am not missing summin.
Thanks
E.Honda
Thanks
E.Honda
Re: WTF is this and where does it go? (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">folding mirrors relay</TD></TR></TABLE>
He is correct and it goes under the right vent inside the dash (RHD). there is a small cubby for placement.
