Refilling bseries coolant? How much? "Honda Type 2"?
Old 11-13-2005, 08:32 PM
turbotime's Avatar
Default Refilling bseries coolant? How much? "Honda Type 2"?
I just did a headgasket change and i need to refill the colant and im wondering how much to buy. From my searching it looks like 4qts ish, but if i could get a hard number that would be good.
I was just going to buy the 50/50 water/glycol mix, is this ok? I read something about honda type 2 blue coolant, whats that? any advantages over water/glycol other than the HONDA name?
Thanks
Old 11-13-2005, 08:44 PM
nighttrain33's Avatar
Default Re: Refilling bseries coolant? How much? "Honda Type 2"? (turbotime)
My Haynes says that it is 4.8 qts.
-Shane
Old 11-13-2005, 08:51 PM
vancoland's Avatar
at the dealership...they sell this big tank of coolant, i think its like 5 qts. for people that want to flush their system...and everything is already mixed. I couldn't find one that's not. They also sell regular 1qt. size if you need it. Type 1 and type 2 coolant just means that they're for different year cars, just tell them what car you have and they'll give you the right bottle.
Old 11-13-2005, 08:54 PM
turbotime's Avatar
i have an obd1 b17a1, so can i just use a water/glycol mix instead of honda fluids?
Old 11-13-2005, 09:05 PM
dpetro1's Avatar
Default Re: (turbotime)
i just used 50/50 water/prestone after my hg install. flushed the system with the prestone super flush and water a few times. from what ive heard any coolant without silicates will work. honda and prestone are ok for sure. i know brands like PEAK contain silicates which ive read is bad for our cooling systems.
edit: i used about a gallon maybe a little more
Old 11-13-2005, 09:23 PM
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">My Haynes says that it is 4.8 qts.
-Shane</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">edit: i used about a gallon maybe a little more</TD></TR></TABLE>
That's about 5 qts.
-Shane
Old 11-13-2005, 09:27 PM
turbotime's Avatar
does the fact that im running a copper headgasket impact the type of coolant i should use?
Old 11-13-2005, 11:44 PM
JDMlyfestyle's Avatar
Ouch.. ive heard HORROR stories about solid copper head gaskets. they leak horribly bad.
Old 11-13-2005, 11:50 PM
turbotime's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Ouch.. ive heard HORROR stories about solid copper head gaskets. they leak horribly bad.
yeah they are tricky to install right, but if they are installed right , they dont leak. You need orings and recieving grooves to properly run a copper headgasket.
dth0ng69
10
07-08-2009 07:49 AM
jek2004
Acura TL, RL & ZDX
08-25-2004 04:00 PM
TypeRuz
11-19-2003 07:57 AM
SamC
03-14-2003 11:10 AM
DC2ITR
05-01-2002 09:15 AM
Quick Reply: Refilling bseries coolant? How much? "Honda Type 2"?
