b16A..just a question...
i recently purchased a B16A motor..do i HAVE to get a cable tranny or is there any hydro trannys available for this motor?
thanx...
thanx...
Re: b16A..just a question... (da_rimrocka3)
the motor came with a cable tranny is what you're saying?? im prety sure it must be obd0... im also prety sure there are conversion kits... i know there is kits to go from hydro to cable
Re: b16A..just a question... (jaydeum4lyfe)
the motor did not come with a tranny...i got it for $200.00 thats why i bought it...the stamp on it says B16A
***correction CIVIC EX COUPE**
yea i am..i'm just in the process of rebuilding it and going to port it out...
so this is a first gen obd1 motor? and it is possible to find a hydro tranny that would work?? if so do u kno the tranny code(s)?
thanx man
thanx man
I got the same engine a couple weeks back you gotta 1st gen b16 if the head hasnt been changed and it says DOHC vtec that comes with a s1 cable tranny if it says dohc VTEC you have a 2nd gen and that is made for a hydro tranny which you will need for your 96 if you find a cable tranny and linkage you can still use it with your car you will just have to buy the cable/hydro conversion kit....hasport makes them check out their website. and if it is the DOHC vtec 1st gen its a JDM and its OBD0 there is no 1st gen b16
Re: b16A..just a question... (BubbleBoyB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubbleBoyB16 »</TD></TR><TR><TD CLASS="quote">I got the same engine a couple weeks back you gotta 1st gen b16 if the head hasnt been changed and it says DOHC vtec that comes with a s1 cable tranny if it says dohc VTEC you have a 2nd gen and that is made for a hydro tranny which you will need for your 96 if you find a cable tranny and linkage you can still use it with your car you will just have to buy the cable/hydro conversion kit....hasport makes them check out their website. and if it is the DOHC vtec 1st gen its a JDM and its OBD0 there is no 1st gen b16</TD></TR></TABLE>
does that have to be all in one sentence??...and it absolutely made no sense
b16a is jdm and honda does rate it at 170hp, but if you're getting it from a car that's an auto, its probably gonna be 160hp
Slotz_HB
08-31-2008 01:29 PM
