Just installed OEM Power Window...Passanger window goes up Slow???
What could be causing that. I've searched before, and found that happens sometimes. I used lithium grease, before, and after the install. What could be the problem???
Re: Just installed OEM Power Window...Passanger window goes up Slow??? (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">Check your voltage...........ground issue............weak *** motor?</TD></TR></TABLE>
What should it be running at. I dont think its a ground issue. It probablly is just a weak motor. O well at least i dont have to reach over. I'm going to keep greasing that bitch
Re: Just installed OEM Power Window...Passanger window goes up Slow??? (AMECustom)
I have this issue as well. I have a 92 si hatch with the power window/lock upgrade. After installing I noticed the driver side was slower. I took everything apart re greased and replaced everything. Then proceed to do the same to the passenger side. There is a wound spring on the track assembly that the drivers side had which the passenger side didn't. It seems to either prevent the window coming down or to help it go back up. So I took it off the manule and put it on the power assembly, now the window struggles. Does anyone know if this spring can be the cause of the problems. Do we even need this spring? It seemed to work fine without it.
Let me know how the grease works for you AMECustom and what kind you used?
Sorry for the long post.
Are you sure the window isent binding up somewhere or you have something adjusted to tight and the motor is fighting that?
To check the voltage get a set of jumper wires and go from the battery to the motor itself. I use jumperpacks sometimes if its easier (The ones for jump starting a car).
Re: Just installed OEM Power Window...Passanger window goes up Slow??? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">Are you sure the window isent binding up somewhere or you have something adjusted to tight and the motor is fighting that?
To check the voltage get a set of jumper wires and go from the battery to the motor itself. I use jumperpacks sometimes if its easier (The ones for jump starting a car).</TD></TR></TABLE>
what could be too tight. All the bolts that hold the acutator to the door need to be secure so the window doesn't move off track. It might be binding along the rubber seals, i'll check when i get home friday. I am college during the week so i dont have a chance to work on the "Red Rocket" all the time lol.
