is there a problem with the fuel injectors??
i just replaced my stock ls injectors wit accel 255cc injectors and now my car seems like it wont start as quick as before..it sounds like its going to die then starts rite up..after u keep the key in for four seconds turned..anyone kno the situation if it happened to u peeps.
Re: is there a problem with the fuel injectors?? (650jdmhatch)
put the stock ones back in cause there's no point in running bigger injectors.. you're just wasting more fuel and making less power.
Re: is there a problem with the fuel injectors?? (kyden)
How long did you use the larger injectors?......If a long time, you could have washed out the rings.
