thin head gasket
Re: thin head gasket (byohnd)
Try custom gasket places. SCEgaskets.com might.
If you want a thin head gasket for higher compression just run without a gasket. But note, when you take off the head youll have to send the block and head to be milled.
I wouldnt just run with out a gasket that is kinda extream, If I were you i'd just take the 3 layer head gasket and just use one layer that is safer than no gasket 0_o G/L
Re: thin head gasket (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Try custom gasket places. SCEgaskets.com might.
If you want a thin head gasket for higher compression just run without a gasket. But note, when you take off the head youll have to send the block and head to be milled. </TD></TR></TABLE>
Probably the dumbest thing you could do. I can't believe some of the info people give on this site....
Just use one layer of a three layer headgasket.
*thud*
dont ever work on your own car.
ever.
*thud*
ever.
Re: thin head gasket (Kamin)
Take a look into the all motor forum. People run without there headgaskets to up the compression. Not smartest thing to do but it can be done. It causes warping though. If thats what he wants to do its there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Take a look into the all motor forum. People run without there headgaskets to up the compression. Not smartest thing to do but it can be done. It causes warping though. If thats what he wants to do its there. </TD></TR></TABLE>
I'd like some examples. Most of the people in that forum seem too smart to do something like that, since milling the head or decking the block would be MUCH safer.
