99 Civic Si Engine Replacement
I'm looking for a engine for a 99 civic si. I just wanted to make sure what kind of engine to order. I beleive a b16a2 comes in a 99 si but want to double check. Is there any recommended upgrades that are still reasonable in the same price range as the normal engine?
Re: 99 Civic Si Engine Replacement (cmillet)
You're new so please use the "Search" function located in the top corner. Also do an "archived" search. Type in B16A2 / B-Series, B16, 99 Si Engine, Etc Etcand tell me what you come up with
Imperious: Mod of Valor
Re: 99 Civic Si Engine Replacement (SRCivic97)
You are the correct, the b16a2 does come in the 99-00 Si cars. I would actually recommend getting a b18c1, or a b18c (JDM GSR). These motors are actually going to put out quite a bit more power if you ask me.
it would help to know what happened to your original engine. for instance, if your transmission is good you could get a r motor, or a b18c and it'd be a pretty significant upgrade. or if your b16 head is still good, build a b20vtec for cheap
guy5978
07-12-2008 01:37 PM
