ACT 4 VS 6 PUCK CLUTCH
Just wondering how many of you out there are running an ACT 4 OR 6 puck sprung clutch? If you have either which pressure plate do you run, (xtreme or heavy duty)? How do you like it? Are you running boost or N/A? Hows the peddle feel? Just curious, looking for boost fairly soon and want to know mainly what the difference/feel is between the 4 and 6 puck. Any one feel free to chime in!
Re: ACT 4 VS 6 PUCK CLUTCH
im runnin a fidanza 6 puck with a lightweight flywheel the car is boosted imo its not the best for daily driving best for track where its in or out...
I would NEVER run a puck clutch for DD unless i had no other option presented to me. They are stiff and they engage choppy, dont like heat well either.
what kind of numbers are you looking to make when your boosted?
I use an act 6 puck clutch with a heavy duty plate and a light weight flywheel. I daily drive this set up and at first it is annoying but i drive it like its a normal clutch. Just takes a matter of getting used to. At first i would spin tires everywhere but now i take off smoothly. Its good for daily use IMO and it gets put to use when i feel like hitting gears. Just have patience in traffic. If u enjoy driving ur car at its full potential then it is worth it.
Anyone else have opinions keep em' coming! Any one running a 4 puck w/ HD pressure plate?
Man U FTW
I couldn't disagree more. I have an Competition Clutch Stage 4 (6pk) and it has nice engagement. Prior to this, i ran an Exedy 3 puck and was also very impressed with its drivability. I don't understand the hesitance to run a pucked clutch. I daily my Integra and have NO complaints about it whatsoever...
Man U FTW
I dont know what kind of power you're looking for, but i'm sure that Competition Clutch makes something that will fit your needs. I heard good reviews about them which is why i purchased one when the time came. I'm not saying that ACT is bad, but i have had great success with my CC Stage 4 and would highly recommend it. Hell, even if you dont need the torque capacity that it offers, the stage 4 is a very streetable clutch and removes the issue of upgrading if/when you decide you want more power.
I don't know if there's anything about Honda's that make them different from other cars in this aspect, but where I come from a Stage 1 competition clutch kit for a Turbo Miata is good for 318lb/ft and is only slightly stiffer than a stock clutch. Even the stage 2 kit is good for 353lb/ft and uses a full surfaced disk. Is there really a need for pucked clutches for anything lower than that?
Well now they are making a sprung version of the clutch's puck 4 and 6 , this guy i knew one time put a 4 puck un sprung act kit in his sohc coup , boosted, killed his legs and take off , then broke off inside his trans because of dd he hated it, but 6 is more of a ok set-up and if it has springs all the better.
but deffenelty not 4 puck. and has any one every seen the pads on the puck discs, they are not worth any life span.
i had the 6 about a few months ago was nice set-up and had lots of hold and clam, the kit is worth it but the full disc clutchs are getting better mad today and are safer and longer lasting.
i had the 6 about a few months ago was nice set-up and had lots of hold and clamp, the kit is worth it but the full disc clutchs are getting better mad today and are safer and longer lasting.
Also redrocket I left out that my 6 puck clutch was an unsprung type. Idk if that makes a difference in your decision, Just trying to be as accurate as possible to help u better.
I never drove a clutch with springs so idk from experience. I do know from what ive read the springs reduce shock on the driveline. But since ive never driven one i cant tell u the difference in how it feels. All i can say is my 6 puck unsprung grabs hard lol I spin up to 4th gear on a 1.6, b16 that is.
yeah i think im gonna try out the sprung for a little while and if i dont like it just sell the disc to my buddy and get an unsprung disc
