what's the difference between gsr and ls pistons??
well the title says it all??? im putting a ls crankshaft in a gsr idk wether to keep the gsr pistons or ls??? help anyone with any ideas...thnx
Re: what's the difference between gsr and ls pistons??
compression is different so the dome on the piston will be different, also consider that the rods on Ls i believe are longer so you will have to take that into consideration, im not 100% sure on rod length being different. Both are 81mm in diameter if the blocks have never been bored.
Just do a google search for b series compression calculator and use that to see the difference.
The LS pistons have a slight dish and GSR pistons are flat tops. ITR pistons look like GSR, but the center section is raised up sort of like a SI piston.
ok you cant use a ls crank with gsr rods. the big end on the gsr rods is too large. so if you want to go with a ls crank you have to use ls rods. also with ls rods i believe you have to mill the small end a little bc its too wide for gsr pistons... the gsr rods are .9mm longer and a the crank has a shorter stroke giving it a less favorable R/S ration than the ls. but the gsr rods are stronger. gsr pistons have higher compression than the ls pistons so you just should stay gsr.
x_doug-x
03-08-2010 06:31 PM
SoOHiGH
05-29-2005 10:15 PM
