type r/gsr air box
type r/gsr air box
are these good? im tryna go oem/jdm style, engine bay having slight adjustments and i wanna know how these are.
What would be a good price for one, and how would it fit in an eg coupe?
im looking at a type r, throw in a k&n drop in, maybe later on go with a cone type filter if i really wanna.
also, are they the same, it looked like it in a picture i got, same size but different tubing
Re: type r/gsr air box
you might want to look into an SIRII airbox
http://www.hmotorsonline.com/shop/wh...l.php?prodID=8
it looks the same as stock but the tube is much bigger, I use it with a K&N drop in with my B16a
the box is the same size as the D series the only difference is the the top half of the box and the tube, it even uses the same filter. When you have the tubes next to each other the D tube looks like a tooth pick. I don't know the size of the d series TB but it should be close enough to fit, I even used the d series clamp that goes on the TB
gl
gl
gl
gl
thanks man
don't think a TB will net you any gains without some other serious engine mods ie turbo cam etc... then you would need a tune, just get a K&N, your not going to see any huge gains with just an intake even if you bought the most expensive one out. You can remove the air baffle/resonator, its a box behind your bumper and connects to the bottom of the air box
what?
Get a CAI and a couple couplers, or a couple intercooler tubing bends and make a pipe that will fit. I did that on a guy's Civic Si and it looks pretty nice.
nice
hahahaha i know
