My Mini-Me Swap *PICS*
Old 02-08-2010, 06:15 PM
ToTriggerHappy's Avatar
Icon6 My Mini-Me Swap *PICS*
Pics of my mini-me swap. Still underway. Will keep it updated. I did this because i had a blown head gasket and thought why the hell not just get the V-Tec. Tell me what you think!!!
Before I started
Piece of **** IM. Im disappointed with the air flow
Dirty a$$ injector out of cylinder #2
Head is off
235,000 miles of carbon on these pistons baby!
Piece of **** HG
10
USED Y8 injectors
11
USED Y8 IM
12
Custom Painted By Me
More pics to come. just ordered much more and cant wait to get it here!!!
Old 02-08-2010, 07:16 PM
D16SiHatch's Avatar
Default Re: My Mini-Me Swap *PICS*
lookin good
Old 02-08-2010, 07:31 PM
Originally Posted by D16SiHatch
lookin good
thanks mann! i wanna finish this **** badd!!!
Old 02-08-2010, 07:34 PM
DVDr's Avatar
That motor has definilty sean better days.
Are you touching the bottom end ? or just doing the mini me swap ?
Old 02-08-2010, 07:36 PM
im doin the mini-me for right now cause im a little low on cash. but once i get paid im takin it out and gettin tt rods and vitara pistons and then throwin in a turbo. plus the v-tec tranny.
Old 02-08-2010, 07:56 PM
LuisV928's Avatar
nice i wanna do this to my single cam to is it alot of work?
Old 02-08-2010, 08:09 PM
gsreg607's Avatar
nice work.... good luck.......more pics when your done...
Old 02-08-2010, 08:12 PM
DVDr's Avatar
Sounds good. Im just saying because most of the swaps I saw that people did the mini me on high mileage blocks without any bottom end work, ended up spinning a bearing.
( you will tend to redline the car alot for the first little while with the mini me swap ).
But if rebuilding the bottom end is in your plans then its all under control.
Old 02-08-2010, 08:15 PM
its really simple work just costs some money. nt too bad tho!
Old 02-08-2010, 08:16 PM
yahh. i never really thought about spinning a bearing. but it makes sense if you think about it. i just wont dogg it untill i get the bottom end work done! thanks for ur input
Old 02-08-2010, 08:53 PM
D16SiHatch's Avatar
its not bearing issues you really have to worry about. what more commonly is the problem, more so on the 88-91 engines, is you throw a fresh newer head and new hg on a bottom end that's high mileage and instead of spinning a bearing it's more likely that you'll blow through the rings and start consuming lots of oil.
i had a d16a6 that ran fine and i decided to mini-me it with a y8 head. it was really clean and nice i thought everything would work out peachy. unfortunately didn't work out that way. it ran fine for a few weeks, but then it started burning lots of oil. did a compression test and cyl 2 came back at 60psi. i said muff this i'm done with the d and went b-series lol.
Old 02-08-2010, 08:57 PM
how many miles did you have on the engine when you did the swap? lets hope this wont happen to me so i can have some time to redo my bottom end.
Old 02-08-2010, 09:01 PM
D16SiHatch's Avatar
i had about 160,000 on the bottom end.
Old 02-09-2010, 04:50 AM
well that sounds bad on my part. i got 235,000
Old 02-09-2010, 08:26 AM
boxeocampeon's Avatar
damn youre head is hella dirty lol
Old 02-09-2010, 08:59 AM
kngkong1256's Avatar
looks clean
Old 02-09-2010, 10:04 AM
724chris's Avatar
what kind of header is that?
Old 02-09-2010, 11:05 AM
Matt93eg's Avatar
I was thinking the same thing. Valvetrain is dirty as hell. That engine would have benefited from oil changes more often.
Old 02-09-2010, 12:19 PM
yahh i know but my mom had it and she didnt really care. but i doo. i change mine every 3000 miles lol. i just wanna use a degreaser once i get my head on. do you know if it would mess up the paint on the valve cover if i do use a degreaser on my engine?
Old 02-09-2010, 12:21 PM
P.O.S. ebay header. i just put it on cause i was low on money and i had a crack on the O2 bung on my stock exhaust mani
Old 02-09-2010, 12:57 PM
D16SiHatch's Avatar
it's possible. i would just pull the cover to be safe
Old 02-09-2010, 01:31 PM
Matt93eg's Avatar
Yeah I agree, I would just pull the cover then you don't have to worry about it. Its only like 5 bolts anyhow.
Old 02-09-2010, 02:55 PM
then what put a trash bag over the head so i dont get n e in it?
Old 02-09-2010, 03:27 PM
keyzek's Avatar
looks good especially the valve cover
Old 02-09-2010, 03:51 PM
wannaBjdmca6's Avatar
hey how did u swap that header? just bolt on?
Quick Reply: My Mini-Me Swap *PICS*
