Help fuel pump not priming 94 hatch
okay i got a another cabin harness for my 94 hatch bcuz i fired my old one
i can only crank the car but cant hear the fuel priming and relay i replace it already...
when i check my fuel pump again i took the plug out and found sum nasty light brown paste in the plug where it connecet to the fuel pump
could dat be the reason why it not priming
Re: Help fuel pump not priming 94 hatch
i would check to see what the fuel pressure is, if there is any at all, if the filter sock on the pump is full of crud it will not have enough volume/pressure to run the car.
the brown junk on the connector is probaby old dielectric grease, i would clean it out and and put some new grease in there.
cleo7
01-23-2013 08:53 AM
happyabortion
12-22-2009 07:59 AM
