oil pressure problem
just did an oil pressure checkon my freshly rebuilt d16y8 and the oil presure is showing at 60 psi at 1500 rpm but the manual calls for 10 psi and 1k rpm does this mean my oil pump is bad or somthing was done wrong?
Re: oil pressure problem
60psi sounds ok to me at idle. My current LS engine sits at 75-80psi at idle when cold. Once warmed up it pumps around 20-25psi at idle and sits at 70-75psi in 5th at 60mph. My old D16Z6 was about the same except it pumped out a higher PSI at idle cold.
ohh i thought somthing was really wrong because it was so high.The engine wasnt completely warm but had been runnning for about 3 minutes
And like I said earlier my LS runs at roughly 75psi cold at idle and then drops to 20-25psi at idle once warmed up good. From the sounds of it, I say enjoy your freshly rebuilt engine. .
BTW I see your from Charlotte. That's cool. I live in Concord not far outside of Charlotte.
thats cools maybe well see eachother at a meet or somthing thanks for the info.I was just worried because i reused the old oil pump and before the engine build the engine had been ran with no oil so i was alittle bit worried about it.
Might see you around but it won't be at a meet. I don't go to any meets do to thieves. I have heard of to many people going to a meet only to have there car stolen later that day/night by someone that followed them home.
DDTECH
31
05-20-2017 12:36 PM
AsSanitySlipsAway
12
08-27-2006 09:55 AM
