what clusters will fit in a 95 civic dx
my cluster on my civic is acting up i was wondering if i could swap any of the of clusters in the acura integra for mine due to the fact that the integra cluster looks better then the civic cluster
Re: what clusters will fit in a 95 civic dx
BAM!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
you can also do s2ks but its a lot of wiring and work, newer civic clusters like the ones on EP3's i think, EK Si and other Ek's since they bolt on (correct me if im wrong), Type R and others just can't remember
EDIT: What do you mean acting up? explain and maybe its not your cluster but a bad sensor or wire
BAM!!!
https://honda-tech.com/forums/showthread.php?t=1053318
Thanks i appreciate the post and by acting up i mean the speed odometer just bounces around doing whatever it wants for the most part with the exception of sometimes telling me the speed ( which is probably wrong) also my gas is empty when it reads quarter tank i think the retards that had the car before me put the cluster in it wrong.....
that speedo thing is the speed sensor and the gas tank thing u might have a messed up float ,, or not adjusted properly, also like u said it could b in there wrong, pull it out and see what wiring is messed up
simplemanseven
12-27-2007 02:17 PM
boost and bass
12-13-2007 07:29 PM
